ā25-03-2024 09:12 PM
Hi, my number has today ported from O2 over to EE but I am not receiving verification codes via SMS but am receiving other messages. My EE sim is also able to take calls but it cannot receive calls from those on Vodafone.. please advise
ā25-03-2024 09:19 PM
Hi @MrJayface did you ever manage to sort this? Iām experiencing the same issues on two numbers after porting from o2. Any advice? Thanks
ā25-03-2024 10:28 PM
If you're not able to receive calls from VF on a ported-in O2 number, I doubt you'll be able to receive calls from any "off-net" user i.e. anyone other than EE.
This is a reliable sign of the porting-data not being fully completed by your donor network, but as you are an EE customer it is for EE-CS to resolve. If you have received a text message to confirm porting complete, you should report the issue to CS on 150.
If they are not able to resolve during the call, they should raise a case to support team.
ā27-03-2024 08:53 AM
I am having the same problem today. Porting over from 3. Unable to link product in my online account as verification texts donāt appear. Was able to receive them before I ported. Did you get it resolved?
ā27-03-2024 09:32 AM
Same here. Needed for the same purpose - to set up My EE app. Ported over from VF yesterday.
ā27-03-2024 09:57 AM
Hi all, mine has been rectified on one line but not the other as of yet. Itās because the porting wasnāt done correctly so was only able to receive calls from within the EE network, once this was rectified I was then able to receive codes and calls. Youāll need to log a case with customer services. Hope this helps
ā13-06-2024 01:41 AM
Me too! I just moved over from 3 mobile in the UK. Then needed to link my product with my ee account. When I have to enter my phone number (that I had from 3 originally now ported to ee) for a verification code, nothing comes through.
When I have to use my phone number for any verification code from Amazon, PlayStation or anything else⦠no codes go through whatsoever.
ā13-06-2024 07:59 AM - edited ā13-06-2024 08:00 AM
Hi @Sssumat
If you are not receiving OTP's please contact our tech guides on 150, and a guide will get this looked into for you.
Thanks š
ā13-06-2024 02:58 PM
ā13-06-2024 03:25 PM
Hi @Sssumat
Thanks for coming back to me.
In this case, please call us again on 150 and the team can get this looked into further for you.
