26 hours after inputting replacement SIM and still no network
sarahf921
Hi, I have an OPPO phone and yesterday at 10am put in the replacement SIM, same number as previous one, as I lost my last SIM card, so it says it doesn't need me to activate it and I wouldn't be able to anyway as you need to receive a text to do so. There's still no network connection even though it says max 24 hours. I've turned it on and off multiple times and reinserted the SIM card and no luck. I can't contact EE for help because the only options are to text or call and I can't do either without connection to a network!
354-
Star Contributor
Star Contributor
@sarahf921 - You can use Skype to call EE on 08000798586.
Or borrow a friend/neighbour/family member's phone to call EE - 07953 966 250
354-
Star Contributor
Star Contributor
