on 16-04-2024 10:16 PM
on 16-04-2024 10:55 PM
I assume you don't have a working SIM and on a pay monthly contract? How have you tried two SIMs? Did EE replace one, and the new one doesn't work?
If you don't have a working SIM you can't request an eSIM as it sends a code to your current SIM to confirm your identity. If you have an EE store near you, pop in with ID and get a new SIM or eSIM.
on 17-04-2024 07:34 AM
Yes to replacement SIM didn't work and paying monthly; can I change deal/contract and get an E SIM that way?
17-04-2024 07:45 AM - edited 17-04-2024 08:16 AM
@KeithBro It’s nothing todo with the tariff to have an eSim . You say you’re a contract customer that means you can have use of the esim in your device. But you will have to call customer service and explain what your issue is and they can get the esim on your device activated without sending you a text to authorise the change to esim.
Can you try those SIM cards in a different device? This way you rule out the sim or your device and can you try a known working sim in your device ?
on 20-04-2024 01:00 PM
on 20-04-2024 02:04 PM
Thanks for getting back to us @KeithBro.
Have you previously been able to use your SIM OK?
If both SIMs don't work in your device this would indicate a device issue rather than a SIM issue.
What phone are you using?
Katie
