25-11-2024 11:02 AM
I cannot use my mobile phone whilst in Poland, cannot make any calls. I tried to fix the issue; changing the limit cup on my phone, mobile date etc. and I am still blocked. Can someone from technical support phione me on my mobile?
Thank you
Michal
25-11-2024 11:15 AM
@Michal29 : No one will contact you from this user discussion group other than thro' the medium of these forums by posts such as this. Anyway we haven't the faintest idea who you are. You need to phone CS.
25-11-2024 04:05 PM
@Michal29 wrote:
I cannot use my mobile phone whilst in Poland, cannot make any calls. .... Can someone from technical support phione me on my mobile?
To add to the previous advice, if the reason for you not being able to make any calls is a lack of roaming - the same problem will affect incoming calls!
