Activate roaming
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2024 01:33 PM
Good day, I have just arrived in South Africa and can not find anywhere on the app for a live chat. What is my best way to get in touch for I can't make calls or txt.
Sincerely,
Frans
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2024 04:04 PM
