I’m in USA and I can’t make it receive calls.
Prit1
I’m in USA and I can’t make it receive calls. I can’t call 150 and EE calls to me drop. I have no data or roaming even though it’s on my plan. I need urgent help and there is no way of getting hold of EE
Post moved to a new thread
Hi I don’t have access to another line, nor a Skype account. I can’t call any number or receive calls. I’m on pay monthly, everytime I’m abroad I have to call EE to add the roaming bundle but this time I can’t even do that. There is no live chat facility either. I’m essentially stuck without any comms when I’m not using the hotel WiFi.
Regards
Pritesh
@Prit1 : Did you receive a Welcome text upon arrival?
Thanks, I’m pay monthly. I’ve activated the roaming but still no luck with calls. It’s shocking EE doesn’t have a live chat option.
Regards
Pritesh
You don't need a roaming bundle to be able to connect to foreign networks, and thus roam. The ability-to-roam is a one-off process and is free-of-charge.
Does your phone show coverage of a local network? Can you send & receive text messages? Did you receive the welcome text message on first arrival?
