06-02-2026 07:40 AM
06-02-2026 10:39 AM
Hi @TonyH10.
Welcome to the community.
Just to add to the information @bristolian has provided, a spend cap can stop texts working abroad, so it’s worth checking or updating this in your EE account. You can find more information on how to set up and manage this on our Set up and manage Spend Cap Help page.
If you’re still having trouble, please get in touch with our team. They will be able to access your account and help further.
Debbie
06-02-2026 08:04 AM
Have SMS worked since you arrived in Turkey? Does your phone show network coverage? Have you been able to make or receive calls since arriving in Turkey? Are you able to send SMS? Are you able to receive SMS?
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
06-02-2026 10:39 AM
Hi @TonyH10.
Debbie
