06-02-2026 09:02 AM - last edited on 24-02-2026 11:14 AM by Linzi_H
[Mod edit: add title]
06-02-2026 09:05 AM
I have paid for a buddle in eygpt but I still can’t make calls.
06-02-2026 12:05 PM
Welcome to the Community, @Wilson12345.
Whilst purchasing a roaming add-on will provide you with an allowance to use whilst you're abroad, this does not actually activate the ability to roam on your account.
Before you travelled did you send a text with ROAMING to 150 to check you were set up?
Also when you landed did you receive a welcome text?
Peter
06-02-2026 12:35 PM
06-02-2026 01:11 PM
Thanks @Wilson12345.
Can you please try another call, but dial the number manually making sure to use the +44 UK country code in place of 0 at the start of the number?
Also do you know if you're able to receive calls, or use other services such as mobile internet?
Peter
