on 07-09-2025 10:24 PM
hi currently in usa and i cannot make calls
Solved! Go to Solution.
on 07-09-2025 10:40 PM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
