Using Data in Tunisia
Hiten096
I arrived in Tunisia yesterday, I'm struggling to connect to any network to use my data. I signed up for ROAMING, i have no spend cap. I need to be able to receive texts for authentication on some of my apps. thanks
7 REPLIES 7
Katie_B
Hello @Hiten096
Welcome to the community.
Did you set up roaming by texting ROAMING to 150?
Have you tried manually searching for another network?
Speak soon,
Katie
@Hiten096   Your data allowance will not cover you while there you’ll need an add on but you need to make sure that roaming is enabled on your account in order to connect to a roaming network.
You might want to read THIS about roaming costs in Tunisia.  And add ons don’t enable roaming they just help keep the costs down.
yes to both.
i just need to be able to receive texts, can i just add that alone?
Northerner
Hi @Hiten096
As @Chris_B said did you activate roaming on your account.
You'll need to connect to WiFi and download and use Skype via the number in my signature to speak to EE CS directly. (UK office hours).
@Hiten096 : As long as you've enabled roaming on your a/c you can receive texts for free. You don't need data for that.
@Hiten096  Did you text ROAMING to 150 before leaving the UK ?  or did you call customer services to request roaming to be enabled on your EE ?
Have you used this device/contract abroad before?
