Unable to receive messages in Thailand
Skunk1990
I'm in thailand and can't send or receive messages but forgot to tell ee that I go abroad how can I start receiving text messages as I cant call 150 as coming up with message 'NETWORK NOT EXCIST '
@Skunk1990 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
