Data roaming calls and internet
Gayathri1
Hi could you please suggest me which is the best roaming data which I can top up to use in India?
@Gayathri1  Text RO INDIA to 150 to see what your options are.   There is no best option,  it’s what’s available for that location and how much you want to pay.
Could you please help me to send the link, so I can see the charges and data
thanks.
@Gayathri1 : Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/india > PAYG.
As  you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
