Unable to make calls from Portugal
garyruss
I am aware a number of EE users in portugal have had an issue making calls after the power outage 5 days ago. My wife and I still cannot make calls (including WiFi calls)
How do we fix?
41 REPLIES 41
Lesley_W
Hi @RDani1985
Thanks for coming to our community.
I'm sorry you are having trouble making calls. I've sent you a private message so I can get some information.
Lesley
LouiseWood1965
I’m in Portugal and since the power outage I can’t make any phone calls…WhatsApp calls are fine, email, internet and everything else is fine but I can’t make a “normal” phone call…any else had the same issue/how did you resolve?
TIA
Hi @LouiseWood1965
If there was an issue with the local network then you'll need to wait until that network is fixed. This is outside of EE control.
Try periodically restarting your device.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
Standard troubleshooting, and several other threads reporting, have you tried manually cycling through the various local networks?
Are your symptoms the same on each one?
Theo2411
Can not call EE because I can not make calls no more after the electricity cut...   Who knows what is going on ,?
Can't make phone calls after the power cut ..     really bad..   can not even call EE
@Theo2411  who knows what’s going on with what ?
If the local network has been affected by power outages this will also include cellular masts as they need power to operate so your device doesn’t connect to a mast as there is no cellular signal to connect too.
Hi .   Did you find out why there is no roaming...    I have same problem..  can't call EE and being stuck in the mountains of Portugal without phone / only what's app
Power cuts to the access network cause a total loss of coverage.
If users can send & receive texts, and/or use mobile data, and/or receive calls, the issue is not coverage related.
We have 9 lines some currently roaming some not noone can make normal calls or texts
