Texts from UAE to uk
pjby50
Hi we will be visiting UAE soon and are wondering what the charges are for texts and phone calls back to the UK. Any help appreciated.
@pjby50 : Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/unitedarabemirates.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
