on 29-08-2024 01:49 AM
I forgot to tell ee I was flying to Canada so roaming could be switched on. I am now unable to call or contact ee to turn roaming on. My phone is open for roaming but it seems locked from ee side. How can I get roaming to start working?
on 29-08-2024 09:07 AM
Hi @Daksha999
Welcome to the community. I hope you're having a great time in Canada so far.
If you're on contract, our Mobile Care team will be able to get it activated from our side for you. Please give us a call from another phone or through a VoIP service, such as Skype. You can find our international contact number on our contact us page.
on 29-08-2024 09:18 AM
on 29-08-2024 10:41 AM
