on 29-08-2024 10:51 AM
Are people having trouble logging in today. I cannot access our business accounts. 2 Directors are not able to make International Calls - one is in the UK, the other in the EU. I cannot check if Roaming is enabled as I cant access any account info.
Does Roaming have to be re-activated every time you come back to the UK from overseas?
Sometimes our calls are included in all the bolt ons we have - and then sometimes they are not and the spend cap gets breached and everything shuts down.
It is a shambles.
on 29-08-2024 10:53 AM
Exactly the same - was working fine, now glitching the whole time as if they keep rebooting the system and removing all the bolt ons etc.
Absolute shambles.
on 29-08-2024 10:55 AM
Can't even login today... says there is a system fault. Try again later.... like it's 1980s
on 29-08-2024 11:22 AM
International roaming is a one-off setting - once activated, it remains so unless you explicitly request it removed.
