Roaming
Donna444
I’ve arrived in Spain. I can’t get onto the app to check my data roaming. When I went onto the app at home it says data roaming £2.47 a day was on my add ons. Should I have had a text message when I arrived in Spain to confirm?
Data roaming simply means using mobile data whilst roaming.
@Donna444 : Yes, if you had the ability to roam activated on your a/c.
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
