Travel to HK
CL890
Hi .. travelling to Hk on Sat.. cheapest way to avoid huge phone and data charges?
thanks
CL
@CL890 : Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/hongkong.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have already used your PAYG SIM to make a call or text in the UK.
Thanks for reply and info! Will look at add ons.👍
