Re: Holiday roaming
Marishajenkins
My data texts and calls won’t work? I’ve had a text to send CAP but it won’t work
@Marishajenkins  are you on contract or PAYG ?  If on contract did you activate roaming by texting roaming to 150 ?   If on PAYG where are you as you might need to purchase a roaming add on or have credit on your account to pay for calls/texts and need to purchase a data add on
Michael_D
Hi @Marishajenkins.
Welcome to the community.
I hope you are enjoying your time away so far. Whereabouts are you?
Is your phone currently showing signal from a local network? Has the phone worked at all since you arrived?
Michael
