19-10-2024 08:17 AM
Hi..
Set up roam abroad pass b4 left uk..here now in Albany WA, phone stuck on SOS only so assume I have no network coverage but why ?
19-10-2024 08:24 AM - edited 19-10-2024 08:25 AM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
