Romming issue
Jacqui1967
I have roaming as an inclusive add on in my mobile package. But I am now I  the usa and when I try to make a call it says I am not connected to a network. So I am unable to make calls or send texts.
@Jacqui1967 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Hi thank you for responding. I didn't activate the roaming before I left for USA as I didn't realise I had to. The problem is I can't call CS or text them to get them to activate roaming and I don't have Skype. So I dont know how I can contact them.
