Roaming issues
Rebecca1520
Hi  iam having the same issue. I did text roaming before I came away but still can not make calls as can not get a network signal.
@Rebecca1520 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Katie_B
Hello @Rebecca1520
Are you connected to a local network?
Did you receive a welcome text when you arrived?
Katie
