Roaming doesn't seem to be working
BecksT83
 I've deleted and re downloaded the app. All sorts as my roaming doesn't seem to be working. I'm peed off. I can't call 150 or anything
[Mod edit: add title]
Swordfishradio
There is a known fault by the look of it, lots of others with the same issue.
Linzi_H
Hi @BecksT83
Welcome to the community.
Just to confirm, are you abroad currently and facing issues using your services? If so, can you please tell us a little bit more about what's happening?
Did you recieve a landing text upon your arrival?
Speak soon,
Linzi
