on 22-08-2024 12:51 PM
i’m in japan too having the same issue and i’m unable to call or text the number provided. i’m unable to do basic things like receiving verification codes. i need help!
22-08-2024 12:58 PM - edited 22-08-2024 01:01 PM
i’m currently in japan (~5 months) and have been having issues (i’m no longer able to do basic things like receiving verification codes - let alone make basic calls or receive texts.) - which is ironically made worse by the fact that i’m unable to call or text the number provided to resolve the issue. i need help!
22-08-2024 01:38 PM - edited 22-08-2024 01:38 PM
@A-_- : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 12-01-2025 06:37 AM
Andriod phones can put apps into a deep sleep if they are not used for a while. This happens to me as my phone has Andriod messages and Google messages installed for some strange reason.
I keep a separate phone for my UK SIM, so to get a text message I have to open the apps screen, seach 'messages' and refresh the notifications setting on them. Then it works like normal.
I hope this works for you.
