Re: Cant make calls Marrakesh
Dickieliggs
I’m currently in Marrakesh I’ve purchased a 7 day pass but can’t make calls or send messages so I’m having issues calling ee even 150 don’t call out
Ali_A
Hi @Dickieliggs
Have you activated World Wide roaming access before going abroad?
Do you have signal while in Marrakesh?
You may need to try manually connecting to an alternative network while there-
For android devices go to Settings > Connections > Mobile Networks > Network Operators > switch "automatic" to OFF.
For apple go to Settings > Mobile Service (or Cellular). Select your active line/eSIM, tap Network Selection.
Wait for it to load with networks. Once loaded, select a different network and wait a few minutes for it to connect.
Ali
