04-05-2025 05:53 PM
I am in Portugal. I cannot make calls.
My settings are all correct, I manually connect to network, turn off/on, nothing works. I cannot even call 150 for help.
What do I do?
04-05-2025 05:50 PM
I am the same. Cannot even call 150.
What do we do?
04-05-2025 06:05 PM - edited 04-05-2025 06:05 PM
@AlthePalErp : Did you receive a Welcome text upon arrival?
