Network unavailable in USA
seasidebob
Hi am in Orlando USA. Since arrival I get network unavailable on my Pixel 3a phone. I have EE Roam Further pass and also roaming enabled on my device and EE account before I left UK. I have automatically select network enabled on my phone. I tried switching that off but returns no networks found. I have tried restarting my device.
Just to confirm, are you saying that your phone does a search for available networks but finds none?
There's your underlying problem, if so.
FYI you have a short time after posting to edit, to negate the need for multiple short replies.
10 REPLIES 10
Katie_J
Hello @seasidebob.
Welcome to the EE Community.
When you arrived did you receive a welcome text?
You mentioned you activated roaming on your account, did you do this by texting ROAMING to 150 or by giving us a call?
Are you aware of anyone else experiencing this?
Katie
seasidebob
Hi @Katie_J no not received welcome text
I text ROAMING to 150 before leaving UK where response was my phone is set up to roam in any country worldwide.
I am only person in my party trying to roam with EE. One of my daughters has a eSIM with a local provider as has connection ok.
Katie_J
Thanks for confirming @seasidebob.
Do you have a spend cap on your account?
Does your phone show No Service?
Speak soon,
Katie
Thanks for swift response @Katie_J
Spend cap is £40
And yes shows No Service.
seasidebob
Thanks for the swift response @Katie_J
Spend cap is £40
My wife is with EE and although not data roaming she did receive welcome text and is showing as network with T-Mobile.
As explained - if I try do manual search on my device it returns no network. I have used my device roaming ok in EU last year. I have checked and my device does have roaming enabled on it.
seasidebob
Thanks @bristolian
Yes returns no networks found. I wonder if that is the problem. Especially as this morning have found my wife with EE does have network connection.
Any ideas of a solution for me here please? Could I try a reset of networks on my device?
How may I retrospectively turn on roaming for my wife with EE? We are now outside the UK so unable to text 150.
What do you mean by "my wife does have network connection". If her phone shows a network connection, can she make/receive calls, send/receive texts and/or use mobile data?
If she can, then she is roaming.
seasidebob
Thanks for your help with this @bristolian and @Katie_J
All sorted now by below
1. Shut down phone
2. Took out SIM
3. Restarted phone
4. Shut down phone again
5. Put SIM back in
6. Restarted phone again. Got welcome text and connection to T-Mobile.
