My phone as been cut off and i am in the usa so need to talk to ee how can i get
kenya25
@kenya25 : How do know it's been cut off? It may just not be working for many reasons. Being cut off implies a deliberate action on the part of EE.
Please type your queries in this big text box, not in the limited subject header which gets truncated.
