I cannot get through to ANY numbers
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-10-2024 01:33 PM - last edited on 03-10-2024 02:49 PM by Linzi_H
This is happening to me
But I cannot get through to ANY numbers to rectify this. I went through your AI service and it said Roaming was activated but I still don't have any service not has any text been sent through
My husband is on O2 and he can't call any of the CS numbers either (for UK or abroad), the call keeps failing
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-10-2024 02:45 PM
Your post has been moved to a new thread, rather than adding to someone else's.
If your phone can't connect to any foreign networks, this will cause a lack of coverage & thus inability to call, text or use mobile data. If you are confident that global roaming is enabled, then manually cycling through each local network in turn usually resolves this. If not, the logical conclusion is that you have not enabled roaming.
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-10-2024 03:12 PM
@Mckemble : Where are you?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 01:11 PM
I have contacted customer service from my husband's phone (which is NOT cheap when we're in a foreign country) the recorded check confirmed I have roaming enabled. I have not been able to get through to an actual human and there is no way to ask for a call back. I am not about to spend £100s on waiting in a 45 minute queue.
I tried to manually search for networks. Nothing came up.
No text message came through when I got to the US.
I even went on EEs useless AI helper thing on their app and it confirmed my roaming was activated.
I have done literally everything in my power to ensure I have followed the paths people keep mentioning in threads, but I am still unable to actually get any proper help from EE because they have no email option
The only way I'm able to actually communicate on here is via WiFi in the hotel.
I need an actual human to help, not cut and paste basic replies that don't answer my problems and show no one is actually reading what I write.
Seriously, the lack of support and the constant gaslighty responses is really making me question whether I should stay with EE.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 01:13 PM
I live in the UK but I'm currently in US on vacation.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 03:26 PM
Hello @Mckemble.
I am sorry to hear you are still unable to use your phone.
Have you tried rebooting your phone since you landed in the States?
If you are a pay monthly customer do you have a spend cap in place on your account?
Have you been able to use your phone abroad before?
Katie
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 03:31 PM
To clarify, are you saying that you've done a manual network search and your phone hasn't found any local networks?
There's your problem if so.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 04:41 PM
I'll remind you that you can try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 10:03 PM
Hi Katie,
Yes I've rebooted my phone about 15 times 😅
No I don't have a spending cap but I (would) have almost all my data available right now anyway.
Yes, I used my phone in Arizona last July
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-10-2024 08:31 AM
Thanks for your reply @Mckemble
Has your phone connected to the network at any point since you landed?
Are you using a physical SIM or an eSIM? Would it be possible to try your SIM in another phone to see if you get the same issue?
Lesley
- I have three simcrard number i need to move ee number in SIM cards & Porting
- Re: Change phone number back to original in SIM cards & Porting
- Can I find out where one of my numbers are in SIM cards & Porting
- Old number ported across, but phone has retained new sim number in SIM cards & Porting
- Call not going through for more than 12 sec in Mobile Network discussions
