I am on holiday in Denmark, I'm unable to make calls!
louismills1
I am on holiday in Denmark, I'm unable to make calls, and unable to call EE on 150 for help - Is there a network problem?
1 ACCEPTED SOLUTION
louismills1
Thanks, success! Fixed with a combination of toggling flight mode and playing with manual and auto networks so all no fine
7 REPLIES 7
A call to 150 is still a call. You've not mentioned whether you've been able to use your phone in Denmark previously, but I will presume the answer is no.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Thanks for your response. I travel to Europe and Denmark regularly this is the first time I have not been able to make calls - any suggestions anyone?
I travelled to Sweden last week from Denmark and received a welcome text when I arrived, but on returning from Sweden to Denmark again yesterday, no Danish welcome text!!
Ritu_D
Good morning @louismills1
Thanks for giving us more information.
I know you have probably already done this but could you try turning the phone off and back on.
You could also try selecting the Network manually to see if that works.
Let me know how you get on.
Ritu
The third paragraph of my post is therefore relevant...
louismills1
Ritu_D
That is great news @louismills1
I hope you have a great time in Denmark.
Ritu
