I am in Spain and my phone doesn’t work.
Eileenmckay2024
I am in Spain and my phone doesn’t work. I’ve already been using somebody else’s phone and I’ve been cussed off three times yesterday. I desperately need my phone.
Katie_J
Hello @Eileenmckay2024.
Thanks for coming here.
Did you activate roaming before leaving the UK?
This can be done by texting ROAMING to 150 or by giving us a call?
Are you pay as you go or pay monthly?
Did you receive a welcome text when you arrived in Spain?
Katie
