Roam abroad pass
Coaly7
I’m Going to the USA
so with the abroad pass add on I can use my phone at no extra cost in the USA?
While in the uk I have unlimited calls texts and data.
also does data roaming need to be selected on my mobile when abroad with the pass active?
@Coaly7 : Outside the EU, as you are on contract, you may use your usual UK allowances there with up to 50 GB data per billing month if you have more, when you have the £25 / billing month Roam Abroad Pass.
If you want to use data you need data roaming to be ON on your device.
As you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
