Can’t make calls or anything
Tomkane
Currently in NZ and I try call or text anyone even 150 it says calls to this number are barred. I just £10 to be hung up by ee and get no where and now I can’t keep doing that. I can’t receive calls or text only texts from pins or we weirdly.. help!!!
@Tomkane  Are you on contract or PAYG ?
Had you used that PAYG SIM for making calls or texts in UK before you left to go abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
I didn’t do this. I wasn’t told to do this by EE customer support. They just said text 159 every now and again to keep your number
