I am abroad and my phone won't pick up a signal.
DJLJinnit
I am in Tenerife - my wife's ee phone is working fine but mine is not picking up a signal. Or roaming etc. I've tried all the settings and I'm confused. Any idea how to fix this? I can't call 150 from here as they won't take a call via WhatsApp or message etc
10 REPLIES 10
OK thanks
The sim was fully activated before we left and all working well.
I'm still confused how to call a uk mobile number 150 without having a signal here only WiFi sorry
DJLJinnit
Ah sorry you said Skype! I'll try to find it  - very old school!!
UPDATE
I spoke to CS this morning and was promised that roaming would be enabled ASAP.
It wasn't
I contacted CS via the ee app messaging 5 hours later and spent over 2 hours talking to an arrar of people and it's still not sorted.
I bought two contracts at the same time. I thought they're identical.
They aren't.
One has roaming on it and one hasn't! And they couldn't even upgrade me!
I bought two the same but they're apparently different. I'm wasting my holiday time talking to EE for ages
I'm going to escalate this to a complaint
Oh and I've still got no signal.
EE talk a good game but their CS is truly terrible. No one follows through - I'm just passed from one person to another. No one has authority. I've used ee community, I've called and used the app. Still not sorted.
Comedy
Is automatic network selection enabled on your device? If so, are you able to switch this to manual and look for a network that way?
I've tried it all Matt.
I'm pretty geeky and know my way around my iPhone well.
No automatic or manual network signal
It is switched off.
As they say - it's them not me 😂
They need to "flick a switch" at their end. I can't do anymore.
To clarify - are you saying that there is no network shown on a manual network search? If so, then no amount of account settings can resolve that, if there's no operator to connect to.
Either way, this has nothing to do with "which contract" you're on - that's immaterial and talk of changing plans won't make a scrap of difference.
The complaints process is perfectly valid to escalate poor service, but it's not a fault reporting avenue. Did CS offer to raise a faults ticket for you? That would be the correct process if their first-line attempts to enable roaming were not working.
To clarify
I can see networks but when I click them nothing happens.
Roaming is switched off at their end.
I've spoken to them for hours on this.
Will call one more time.
I don't need anymore help here tbh just letting people know the outcome.
EE sometimes fails and doesn’t give good CS - it's not all unicorns and sweetie shops regarding this issue I'm afraid.
I'll sort it.
Thanks everyone. No more responses needed, keeping this here to help others.
