Cannot use Roaming in USA
DgAllo
we are in USA, have purchased Roam further and are unable to make ANY calls, even with wi-fi calls enabled. Have walked through all help steps to no avail.  CANNOT call customer service as I cannot make ANY calls.
Apple iPhone 14 running iOS 18.0.1
Please someone help?
