Signal
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
20-11-2024 04:34 PM
Hi please can u help me, I’m currently in U&E and forgot to tell u so I would have mobile signal upon my arrival, I have been the app 2 days ago and added the 120 min anywhere add on and I still have no signal ! I need to have a signal. I can’t call u as per the app help as I have no signal. I’ve also tried to text world to 150 and that doesn’t work either, please can u assist?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
20-11-2024 04:39 PM
