on 13-07-2025 11:56 PM
Hi, I’m in Lisbon (Portugal) and I’m not getting any signal or 4G. Tried to find an add on but the EE app isn’t working! Any suggestions ?
on 14-07-2025 01:32 AM
@Annaph90 : Did you receive a Welcome text upon arrival?
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
