How do i buy a roaming abroad pass with EE
gemhallin
I'm trying to work out hie to buy a roaming abroad pass on the ee website.
  • It comes up with a page telling me to turn off my WiFi and then turn it on again've done this but it still hasn't changed anything.I want to buy a 7 day pass for £25 and the whole process seems really complicated!
I font want to ring customer services as I'm abroad and I will be charged!
im not an overtly technical oerson so need 'lamens terms' style instructions!
6 REPLIES 6
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. When you first arrive abroad and connect to a foreign network, you'll receive a welcome text message with a link from where you can purchase add-ons and roaming passes.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Hi, yes I have received a welcome text message from EE, so assume that means I have 'roaming enabled' on my phone?    If that's the case then what do I do next?
Rach_H
If you turn your WiFi off and try and connect to the internet are you prompted to try and buy a pack @gemhallin?
Alternatively if you text 'ROAM' to 150 then you should be given the options to add this.
Rach
@gemhallin wrote:
Hi, yes I have received a welcome text message from EE...what do I do next?
That text message should contain a link - click on it to load the page from where you can select which pass you want to purchase.
I am trying to buy for my partner already there. I am account holder.she is already abroad
Leanne_T
Morning @Beqir1980
Does your partner have signal and get a text message to purchase a roaming pass when they landed?
If not, please give us a call on 150 and the team can check the account is fully set up for roaming and see what roaming add-on's are available 🙂
