19-10-2026 06:20 AM
Un able to add data. Add ons only list roaming packages not a data purchases.
19-10-2026 06:23 AM
Visit http://add-on.ee.co.uk/purchase when not connected to WiFi to see what data add-ons are available.
19-10-2026 07:24 AM
it says i have data and does not let my buy data. So your solution does not work.
19-10-2026 08:44 AM
What happens when you tap on ''Buy data"?
19-10-2026 12:59 PM
It only gives you the option to buy roaming packages not the ability to buy data. I have spoken to one of the EE team and they found the same issue.
21-10-2026 05:57 AM
The app and website buy (add) data function did not work. I had to call EE and get a human to add thr data. The only service avaible was to purchase roaming packages. I suggest EE fix this problem so users can buy data as advertised.
21-10-2026 06:03 AM
you can clearly see here, I have purchased the add on, yet it is not added to my account ?
22-10-2026 03:53 PM
Hi @howard23
If you're still having this problem, I recommend speaking with our customer support team, so they can check everything from our side for you.
Let us know how you get on please.
