Connection issues
NkalaL
Hie am in Morocco and was told my phone will connect when I  land in Marakech and now gone blank and not able to access my phone.
@NkalaL : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
