on 13-11-2024 05:26 PM
I cannot receive any text messages abroad , when I have always been able.
on 13-11-2024 05:32 PM
Can you make calls & texts?
on 13-11-2024 05:48 PM
When you say "I have always been able", are you saying you have used this phone abroad previously? If so, roaming was enabled at one stage, and the issue lies elsewhere.
Are you on PAYG or pay-monthly? Have you tried selecting alternate local networks in your host country?
