Can't make or receive calls in Dubai
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-12-2024 11:55 AM
Hello,
In Dubai and can't seem to make or receive any calls on my iPhone. I am with EE and the help line number doesn't connect...
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-12-2024 12:30 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-12-2024 02:16 PM
1. I am on contract with EE.
2. I did not let EE know I was leaving the country.
3. I received a text upon arrival in UAE from EE. Saying welcome etc.
4. I have upped my cap. Never asked for a cap…
5. My phone remains unable to receive or make calls.
6. What number do I call from another device?
Thanks!
The information contained in this email message may be confidential. If you are not the intended recipient, any use, interference with, disclosure or copying of this material is unauthorised and prohibited. Although this message and any attachments are believed to be free of viruses, no responsibility is accepted by Lisa Thomas Management Ltd for any loss or damage arising in any way and in accordance with lawful business practices. If you have received this message in error, please notify us by return and delete the message and any attachments. Lisa Thomas Management Limited, London. company Registration 05246108.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-12-2024 02:34 PM
If you received a text message on arrival, then your phone has a connection to a local network and thus roaming is enabled.
Try manually selecting alternative local operators, check whether the symptoms are the same on each. If symptoms vary, it could be a local network issue - if symptoms are the same, it could be an EE issue.
