on 12-08-2025 01:05 PM
I have purchase the sim from uk and now I'm in pakistan when I call the some one in UK the operator tells "this number is bard". What I need to do?
Solved! Go to Solution.
on 19-08-2025 12:05 PM
Can I used App to enable roaming?
on 19-08-2025 12:13 PM
@Tiktokshop Have you managed to get your number linked to your app account? It is not possible to activate roaming via the app, for Pay as you go numbers it can only be activated via chargeable activity whilst you are in the UK.
If you do have it linked up you should be able to check you have an actual credit balance to use for calls, if you did want to test a text, if that works that should mean roaming is enabled and there may be a different issue with your calls.
Have you tried calling our contact us from abroad number, +44 (0)7953 966 150 to see if that works?
Alex
on 20-08-2025 06:54 AM
I have tried calling this number but the operator responds with "this number is abard". And I have checked the BALANCE it has 5 pound BALANCE
on 20-08-2025 08:10 AM
And I can't send text as well
on 20-08-2025 08:32 AM
@Tiktokshop I am sorry to hear that thanks for checking, is the £5 all you have topped up previously? As if you have topped up £5 and still have £5 available it would mean there had been no chargeable activity when in the UK.
That would mean unfortunately it will not have been activated for usage outside the UK.
Alex
