on 18-01-2025 11:14 AM - last edited on 21-01-2025 11:50 AM by Peter_W
Hiya, could you please clarify what '7 Day Charge - NO' means? Thank you!
[Mod edit - Added title]
Solved! Go to Solution.
20-01-2025 05:01 PM - edited 20-01-2025 05:05 PM
@Leanne_T : OIC what was meant! In this case the pass only covers 1 day. So it's not really sitting in the background beyond the day it was bought. So the OP will need to keep buying daily passes if they don't know which days the calls are coming in..
@meili : If you don't know when you might be called you might need to buy the daily pass for every day of your hols. That would be 13 x £7.50 = £97.50. It'll be cheaper just to pay the standard call rate of £2.34 / min for incoming calls & not buy any passes.
on 21-01-2025 04:28 PM
Hi @meili
Sorry for any confusion around this. I've looked into this further and it doesn't quite work as I said it would. For these add-ons, you actually have to select the add-on for each day that you want it. It doesn't automatically charge like I thought it did.
You'll have the option whilst you're there to select the add-on as and when you need it.
Sorry again for any confusion.
