on 20-01-2025 04:23 PM
Hi, does anyone know how to get roaming working abroad on pay as you go. I've tried sending a text to 150 as per the text I received with ROAMEU7D but it doesn't send? Any ideas?
on 20-01-2025 05:32 PM
Where are you? Did you use that PAYG SIM previously in the UK?
on 20-01-2025 11:10 PM
@Ccc7 , pay as you go is automatically enabled for roaming, but will only work if you have activated your SIM card in the §uk first and made a chargeable call or text in the UK first
