on 22-11-2022 04:05 PM
Hello
I have an EE Simcard but I use it abroad in another country
My Simcard is working on my local carrier and I just use it to receive SMS and some phone calls
what should I do to keep my Simcard alive and use it for a long time?
should I top up every specified period? if yes how much and how long ?
please help me with these questions
Solved! Go to Solution.
on 22-11-2022 04:44 PM
@highlander926 : EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You need to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
on 22-11-2022 04:55 PM
thank you for clear answer
can I do this chargeable actions while I am abroad? from another country ?
22-11-2022 05:00 PM - edited 22-11-2022 05:01 PM
Yes, you may top-up online or when in EU buy a pack or add-on from your MyEE.
