Help Needed: Reactivating Long-Inactive EE SIM While Abroad
afan_zaheer
Hi everyone,
I’m currently facing an issue with my EE SIM. I have a UK EE SIM that I haven’t used for 6–8 months and I’m now in Pakistan. Recently, I’ve noticed:
  • Calls to and from the number are barred.
  • USSD codes (like *#100#) show unknown error.
  • EE is sending top-up reminder messages.
  • WhatsApp is still active on this number, but I cannot receive verification codes.
  • My phone shows Ufone as the network, likely due to roaming.
I want to know:
  1. Can I reactivate this SIM from abroad by topping up?
  2. Is it still possible to keep this number alive and receive WhatsApp codes?
  3. Has anyone successfully reactivated a long-inactive EE SIM while abroad? If yes, what steps worked?
Any guidance or personal experience would be very helpful. Thank you in advance!
@afan_zaheer : After over 6 months of non-use your PAYG SIM has gone into hibernation. Topping-up now would be too late. It's possible you now have a month of grace to contact EE & get it back.
EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
