Roaming problem
Paakay
I am using a pay as you go sim and currently outside UK. I have enabled roaming service on my phone and my ee network is connected to a local network alright and the roaming service is on but i can’t make or receive calls. It keeps on telsaying my phone is not available. Current i can’t make or receive calls. Can anyone help me. Thanks
8 REPLIES 8
@Paakay  Did you use that sim in the UK first ?  Where abouts are you?  Because different locations will give you different answers  to your question.
Roaming is not something you enable on your phone, it's an account-level setting. You may be confused with "data roaming" which just allows the use of mobile data whilst already roaming.
yeah i did and i am in Ghana at the moment
i have received the initial message from EE. Welcome to ghana and all roaming charges were stated in the text message. so how come i can't receive, make calls or text messages.
@Paakay wrote:
i have received the initial message from EE.... so how come i can't receive, make calls or text messages.
In which case the third paragraph of my previous post applies.
When did you previously make a chargeable action on that PAYG SIM? You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
i have airtime on my sim but my calls and text are not going through.
That wasn't what I asked you.
