No signal or data
hortonsassembly
I am on pay as you go and have 30GB of data however since last night it’s not connecting to the internet. I also have no signal but can still call and text? I have restarted the phone, reset the network settings and took the sim card out, please help?
Mobile data uses the same network signal as calls & texts, so if you have no coverage then the only way you will be able to make & receive calls is by using WiFi-calling. If you've removed the SIM, it will stop WiFi-calling from working.
If you are using WiFi without a SIM, it follows that your internet connection has nothing to do with EE's mobile network.
There is a SIM card in the phone however I can’t use my data but I can make calls and send texts
What does texting AL to 150 from it fully report verbatim (it is free)?
