28-07-2023 04:06 PM
Hello there !
I’ve been away for long time and just came back. But my EE sim doesn’t seem to work at all, cannot get any call or messages … what can I do?
28-07-2023 07:09 PM
Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
28-07-2023 05:25 PM
Hello @Alejandra1.
If your pay as you go SIM has not been used in 10 months then it sounds like your SIM has gone into hibernation/has already been disconnected.
I would recommend getting in touch with our customer care team.
You can find more information on EE pay as you go hibernation HERE.
Katie
28-07-2023 07:09 PM
30-07-2023 12:31 PM
Hello, thanks for the reply !
I just called EE and they told me to order the sim online and keep my number. I’m now looking to order it now but I can’t find a ‘Pay as you Go sim’ there’s just monthly / yearly plans ….
what do you recommend?
thanks
30-07-2023 12:33 PM
30-07-2023 12:42 PM
when I try to order online this appears 😔
30-07-2023 01:05 PM
Try another browser. I had trouble with 1 of mine on that page.
30-07-2023 02:08 PM
Thank you very much for the reply, I’ll have a look now on my pc… Another question. As I want to keep my number, once I order the new sim they’ll ask for my PAC code but I can’t get it by message as I don't have any signal to get any messages or calls 😔
How can I order the new sim without loosing my current number without my Pac code?
thanks a lot
30-07-2023 02:25 PM
You can't! You've lost your no. as it's been unused for more than 9 months.
